Crank to use.
I am building a motor
korrodo cases
80 metra large port
I am not sure as to what crank I should use. I was thinking about a dmp unstuffed.
also which clutch should I use?
Re: Crank to use.
stuffed dmp with the stuffing removed.
Re: Crank to use.
is dmp stuffed with stuffin removed different than the dmp unstuffed?
what about the rito crank too? isnt that better?
Re: Crank to use.
the dmp stuffed as oiling holes on the small end of the con rod and a slit on the big end the unstuffed dos not i did not like the rito i just got a stuffed kstar and i was going to take the stuffing out but it seams much harder than my dmp so i am just going to run it
Re: Crank to use.
good info. stuffed kstar? does that have a goodoil holes?
Re: Crank to use.
got it.
