Re: Gianelli Sachs mounting
Mike Bartell /
markryan- 504's a simpler engine than the 505- no pedal shaft drag, and the flywheel is smaller. Strength wise they are the same - you can actually bolt a 504 and 505 case together like half and half, but you wouldn't have a sealed up transmission. They are that much alike.
Nerdy (wade?) - the connection pipe on the bottom of sachs heads always work loose- they come from the factory tight, but they wear out pretty quick. Use springs from anything you can find, if you want to go that route.
Jafar- I'm going to try a knock off Dellorto 15 when I get time, and jets. I still need to press apart my busted up D crank and try that again.
Lessons I learned- 1-Cut up lock washer will work as a woodruff key but is too strong and will mess up the shaft if anything goes wrong.
2- When you press apart a crank, index everything and double check it - I never got the timing right.
  Gianelli Sachs mountingTopic by: Mike Bartell Mike Bartell 02/07/09 03:37AM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/07/09 03:38AM
  Re: Gianelli Sachs mountingRe: Ja'Far Rogers Ja'Far Rogers 02/07/09 11:22AM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/07/09 02:11PM
  Re: Gianelli Sachs mountingRe: Jesse -B Jesse -B 02/07/09 08:37PM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/07/09 09:01PM
  Re: Gianelli Sachs mountingRe: Jesse -B Jesse -B 02/08/09 09:56AM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/08/09 11:05PM
  Re: Gianelli Sachs mountingRe: Jesse -B Jesse -B 02/08/09 11:25PM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/09/09 01:06AM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/09/09 07:03PM
  Re: Gianelli Sachs mountingRe: will will 02/09/09 08:35PM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/10/09 12:23PM
  Re: Gianelli Sachs mountingRe: Metrakittens Metrakittens 02/10/09 05:25PM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/10/09 07:01PM
  Re: Gianelli Sachs mountingRe: Ja'Far Rogers Ja'Far Rogers 02/10/09 07:30PM
  Re: Gianelli Sachs mountingRe: Metrakittens Metrakittens 02/10/09 10:05PM
  Re: Gianelli Sachs mountingRe: maggie on markryan maggie on markryan 02/10/09 10:11PM
  Re: Gianelli Sachs mountingRe: Garelli Master✨ Garelli Master✨ 02/11/20 09:07AM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/15/09 10:59PM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/16/09 03:57AM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/16/09 09:02PM
  Re: Gianelli Sachs mountingRe: andrewhed andrewhed 02/16/09 09:21PM
  Re: Gianelli Sachs mountingRe: Born to be WillD Born to be WillD 02/18/20 03:47PM
  Re: Gianelli Sachs mountingRe: ♣Slew Foot♣ ♣Slew Foot♣ 02/19/20 06:12AM
