Re: Gianelli Sachs mounting
Ja'Far Rogers /
mbartell
A 15mm carb like Amal 15 would work well with that pipe provided you set the needlepin to the appropriate notch. The Amal is a very hard-to-tune carb but once the carb, piston rpm, and the gianelli's midrange design synchronize the power is amazing. The way you have your carb setup is for higher powerband pipes because of the distance b/w the airbox and the widest part of the expansion pipe. Try a different carb or chop the airbox in half.
Btw, you're not going to see much faster than 34mph if you don't use taller gearing.
  Gianelli Sachs mountingTopic by: Mike Bartell Mike Bartell 02/07/09 03:37AM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/07/09 03:38AM
  Re: Gianelli Sachs mountingRe: Ja'Far Rogers Ja'Far Rogers 02/07/09 11:22AM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/07/09 02:11PM
  Re: Gianelli Sachs mountingRe: Jesse -B Jesse -B 02/07/09 08:37PM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/07/09 09:01PM
  Re: Gianelli Sachs mountingRe: Jesse -B Jesse -B 02/08/09 09:56AM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/08/09 11:05PM
  Re: Gianelli Sachs mountingRe: Jesse -B Jesse -B 02/08/09 11:25PM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/09/09 01:06AM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/09/09 07:03PM
  Re: Gianelli Sachs mountingRe: will will 02/09/09 08:35PM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/10/09 12:23PM
  Re: Gianelli Sachs mountingRe: Metrakittens Metrakittens 02/10/09 05:25PM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/10/09 07:01PM
  Re: Gianelli Sachs mountingRe: Ja'Far Rogers Ja'Far Rogers 02/10/09 07:30PM
  Re: Gianelli Sachs mountingRe: Metrakittens Metrakittens 02/10/09 10:05PM
  Re: Gianelli Sachs mountingRe: maggie on markryan maggie on markryan 02/10/09 10:11PM
  Re: Gianelli Sachs mountingRe: Garelli Master✨ Garelli Master✨ 02/11/20 09:07AM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/15/09 10:59PM
  Re: Gianelli Sachs mountingRe: Mike Bartell Mike Bartell 02/16/09 03:57AM
  Re: Gianelli Sachs mountingRe: nerdzilla No mo Peds no mo nerdzilla No mo Peds no mo 02/16/09 09:02PM
  Re: Gianelli Sachs mountingRe: andrewhed andrewhed 02/16/09 09:21PM
  Re: Gianelli Sachs mountingRe: Born to be WillD Born to be WillD 02/18/20 03:47PM
  Re: Gianelli Sachs mountingRe: ♣Slew Foot♣ ♣Slew Foot♣ 02/19/20 06:12AM
