what is the largest size tire that will fit (without rubbing) on a pa50, without making modifications?
For gazelles which are wide. 2.25 front and 2.5 rear... maybe bigger in the rear. The 2.25 in the front is really close and will rub the fender unless you wheel is perfectly true. Had to bend the fender ever so slightly no the front.
