Rain vs Belts
so it was raining pretty hard this morning and my engine kept revving the fuck out and then engaging very hard after i got into the downpour.
what can be done about water in a downpour on a french bike?
Re: Rain vs Belts
nothing to my knowledge.
i have the same problem with my ciao.
Re: Rain vs Belts
ziptie a hair dryer to your bike, pointed at the variator where the belt first contacts it. you'll need a reeeaaallly long extension cord. :)
side covers do help. fabricate some.
Re: Rain vs Belts
Depends on the belt trying switching it out. Some belts will slip but catch hard and others will slip and slowly engage, at least you won't have the breaking shit sudden jerk of acceleration. Part of my choices when it comes to belt is toward the wet weather side of things up in seattle. What belt did you have on the bike?
-naz
Re: Rain vs Belts
i just took the belt off. stopped using it entirely.
Re: Rain vs Belts
get a bicycle.
Re: Rain vs Belts
so then i can be more wet, and sweaty?
Re: Rain vs Belts
Get a car then if you don't like water and exercise.
The stock moby setup with the side covers and variator cover seemed to work pretty well in keeping the belt, or at most the variator somewhat dry.
Re: Rain vs Belts
side covers = plastic splinter leg death in an accident. at least on a 103. no thanks.
Re: Rain vs Belts
plastic? Oh, on a 103.
I have a mud flap thing on my front fender. That combined with the normal variator cover and side plates keep it OK.
Re: Rain vs Belts
all that stuff makes me go at least 7 mph slower.
come on!
Re: Rain vs Belts
you can just ride your maxi in the rain, no?
yeah, go for the side panels option. its your best bet other than that.
i like riding my bike in the rain, it keeps you warmer cause youre gonna get wet either way, so atleast youre exercising.
i have extra side panels by the way, not sure if i want to keep em or not.
Re: Rain vs Belts
I would think pedals protect your side panels in a wreck
Re: Rain vs Belts
what you know about rain, fool?!
Re: Rain vs Belts
French bikes just fail in the rain.
I find that once i'm going, the belt dries out nicely. I just have to be light on the throttle while taking off from a stop. When running the variator cover, it helps marginally. that thing really doesn't do anything though.
Re: Rain vs Belts
my maxi doesnt have a belt andrew.
akpasta, you are wrong. i have crashed enough times to say this with certainty, and if your legs are on the pedals and smashed between ground and shattery plastic, pedals continue to not help.
i rigged up the hairdryer set up, pics later. it works ok.
Re: Rain vs Belts
Get a VeloSolex. It's French and no belt!
