Can someone plz take a moment to measure the inflated tread width of an M29s 16" x 2.75" for me....pleassssssse
Need to know if they're going to fit on my rigid before purchase.
If it's not done by this afternoon I will mike them when I get to the shop around 5 and let you know.
Thx James!
bump...
76mm wide x about 68mm off the rim.
I thought the width of given was supposed to be the width at its fattest point when inflated. but hey a 2X4 is neither two nor four.
Thanks James...
I have a set on five stars on my rigid maxi they fit just fine
Not Maxi...tis Swinger...and it will be very close.
the rigid swinger has a will take a wider tire than the rigid maxi so you should be fine
