Does anyone run this sutup. How is it working out.
Also how is the fit
what kit are you planning on running, the kits porting determines the pipe you want to run. G3 is a good pipe but there are better matches for most kits.
and oh ya, that doppler spring is critical, or well at least a better tensioner spring then stock. I'm running the stock av10 cases ported out to huge with stock cdi, running the larger polini reed box and a 21 phbg, doppler pipe and malossi varplus variator with a pull start. works great!
What does the doppler tension spring give u over stock? Is it adjustable? Does it compress farther back? With more tension I thought it was meant to work in conjunction with the doppler clutch pulley.
I've got the 70 polini< i was just wondering if the pipe rubs up on the spring for some people.
i dont rub, ever.
The doppler spring gives you a much better performing spring for any kitted av10. It's much stronger and better build then a stock spring. It will force the variator into a lower gear when you let off the throttle much faster then the stock spring.
I've never had problems with the doppler pipe and the spring.
