cdi jetting
Did you have to down jet, upjet, or do anything strange after installing the cdi?
kthanks.
Re: cdi jetting
you shouldnt have to do much. but you might what to make a bigger gap on your plug just a "bit".
with 12v cdi's they have more jucie behind them and can afford a little bigger gap .
just get the timing right and you should be good to go
Re: cdi jetting
how wide a plug gap are people running on the hpi btw? my understanding is basically you try to get away with as wide as you can without misfiring at peak rpm, right?
