Re: Nicosil replating??????
Hey Ilia, Its fine. I was talking about replating my old cylinder which is toast. Pull a dyno run on the black mamba today and shes puttin out 8hp at the rear wheel. Came home and reworked the clutches and went up a tooth on the front sprocket. Think its going to be pushing 60mph hard now as the dyno indicated 55.3 mph and wasnt held at topend for more than a split second. Think its going to live. Also I am running 36:1 mix with high test because of the comprssion ratio is high 190psi. Thanks and remember spring rally here is around the corner. Keep in touch!
