Magnum Tail Light... LED... ????
Honk /
Before I get scolded, I know that this isn't a performance question per se but this is obviously the forum to get reasonable technical answers without having to read through chicks with dicks or music posts on the general board. So...
I'm working on a cafe-ish project with my Magnum and I need some tail light advice. I'd like to run a LED tail light either mounted under the seat or in the rear trunk.
Will I be able to use one designed for a motorcycle because most of those are designed to just plug into the specific electronics of the bike and/or have turn signals built in?
Can I just cut off the connector and wire it up?
Mopeds are 12v and motorcycles are 12v but obviously they have a battery so, will that cause an issue?
Help a novice out here with any specifics from those who have done something similar...
Thanks.
