My stock throttle has a plate with a screw that holds its location on the throttle body. The bottom of the plate adjusts how far the pull is on the throttle. I had to adjust it all the way back, but it does work with a PHBG.
If you don't have one of the adjustable ones, then get one from 1977 like the above poster said (or a local motorcycle store usually carries them.)
