magnum kit???
i have a stock magnum xk, i am looking to kit it out, i am trying to avoid rebuilding the engine, do i need a new crank? bearing? seals? i am thinking 75cc. gila maybe?
magnum kit???
With that kit you absolutely need to tear the engine apart.
Re: magnum kit???
Re: magnum kit???
^yes, if you are going to bolt it on, get the K start kit. Gila is out of the question if you are unsure about whether it requires you to rebuild (not trying to be a dick...but it requires rebuild, adding material to the case, and boring/milling it to accept the large transfer ports). If I were you, I'd bolt on the K-star or try to case match it without splitting the case (use the search function and you will find a thread showing you how to use playdough to do it). Good luck.
Re: magnum kit???
ahhh gila's do not require to add more metal same ports as a small port metra 80.
