Re: Tates new theory on NO2
Graham Motzing /
no2 just adds oxygen to the burn process and lowers the temp of incoming air, so if you remove enough oxygen by choking it, to balance out the mixture, you end up with the same mixture and same amount of power.
roald is right, you need a wet shot kit to run n02 on a carb'd vehicle, or a really fancy carburetor
