Winter Project
ottoman /
So I got bored and started a new motor for my Maxi.
Found a old KX80 top end... a Wiseco Yamaha piston (50.5mm) to fit the Puch wrist pin size and a chunk of 1.5" aluminum.
Threw the cases in the mill and mowed the deck off. Milled the aluminum to the correct shape and cut it in half. Lined everything up with the case halfs and welded it togther... added a lot of filler material to allow me to cut in the transfer ports with out breaking out.
Then I did a little calculating and determined the proper case height to obtain a zero piston to deck height with no base gasket and milled the case to this demension. Drilled and tapped the cyl mounting stud holes.
So far I see no reason it wont work....
Next I will rough out the ports on the mill and finish with the hand grinder.
I hope to have it in and running by spring.
  Winter ProjectTopic by: ottoman ottoman 01/25/09 08:45PM
  Re: Winter ProjectRe: ottoman ottoman 01/25/09 08:46PM
  Re: Winter ProjectRe: ottoman ottoman 01/25/09 08:47PM
  Re: Winter ProjectRe: ottoman ottoman 01/25/09 08:48PM
  Re: Winter ProjectRe: finny finny 01/25/09 08:53PM
  Winter ProjectRe: Brennan O. Brennan O. 01/25/09 08:54PM
  Re: Winter ProjectRe: Mick Baltards Mick Baltards 01/25/09 08:56PM
  Re: Winter ProjectRe: ottoman ottoman 01/25/09 09:14PM
  Re: Winter ProjectRe: JeremyCA JeremyCA 11/15/09 01:00AM
  Re: Winter ProjectRe: Nash . Nash . 11/15/09 01:53AM
  Re: Winter ProjectRe: GR/NDER GR/NDER 11/15/09 03:19PM
  Re: Winter ProjectRe: chris chris 02/27/10 09:59PM
  Re: Winter ProjectRe: steve steve 01/25/09 08:58PM
  Re: Winter ProjectRe: ottoman ottoman 01/25/09 08:59PM
  Re: Winter ProjectRe: motobee motobee 01/25/09 09:10PM
  Re: Winter ProjectRe: finny finny 01/25/09 09:30PM
  Re: Winter ProjectRe: Todd rod Todd rod 01/25/09 10:37PM
  Re: Winter ProjectRe: Speed fiend Speed fiend 01/01/10 10:07PM
  Re: Winter ProjectRe: ottoman ottoman 01/25/09 11:57PM
  Re: Winter ProjectRe: Charlie BUZZARD Charlie BUZZARD 11/17/09 03:30AM
  Re: Winter ProjectRe: ottoman ottoman 11/17/09 03:56PM
  Re: Winter ProjectRe: Raymond Wright IV Raymond Wright IV 11/17/09 08:43PM
  Re: Winter ProjectRe: Chris Paz Chris Paz 11/17/09 09:24PM
  Re: Winter ProjectRe: ottoman ottoman 11/18/09 02:52AM
  Re: Winter ProjectRe: Speed fiend Speed fiend 01/01/10 10:08PM
  Re: Winter ProjectRe: dean playing god on rafter's account dean playing god on rafter's account 02/27/10 10:09PM
  Re: Winter ProjectRe: Colin R. Colin R. 02/27/10 10:18PM
  Re: Winter ProjectRe: Bill_O_MAtic Bill_O_MAtic 02/27/10 11:29PM
  Re: Winter ProjectRe: ottoman ottoman 02/28/10 03:55AM
  Re: Winter ProjectRe: clayton clayton 02/28/10 05:20PM
