Winter Project
So I got bored and started a new motor for my Maxi.
Found a old KX80 top end... a Wiseco Yamaha piston (50.5mm) to fit the Puch wrist pin size and a chunk of 1.5" aluminum.
Threw the cases in the mill and mowed the deck off. Milled the aluminum to the correct shape and cut it in half. Lined everything up with the case halfs and welded it togther... added a lot of filler material to allow me to cut in the transfer ports with out breaking out.
Then I did a little calculating and determined the proper case height to obtain a zero piston to deck height with no base gasket and milled the case to this demension. Drilled and tapped the cyl mounting stud holes.
So far I see no reason it wont work....
Next I will rough out the ports on the mill and finish with the hand grinder.
I hope to have it in and running by spring.
Re: Winter Project
Another pic
Re: Winter Project
another
Re: Winter Project
KX cyl
Re: Winter Project
That's gonna be sick! Great work! Look at the stock transfers, they are 1/8th the size of the new ones!
Winter Project
Wow.
Re: Winter Project
fuckin A those transfers are sick! When you said "old KX80" I thought for sure the pic would be a crusty, giant-finned aircooled monster.
Re: Winter Project
fuck yes.
Re: Winter Project
Here is a pic of the pipe I plan to use... with a lot of modifications..lol
Its a custom built KX80 pipe I found cheap... almost too nice to cut up.
Re: Winter Project
this is going to be awesome.
Re: Winter Project
The KX top end is from the late 80's, water cooled.
Its going out next week to be re nicasil'd. Nice thing is Millenium (Nicasil place) is only 14 miles from my house.
I figure it should end up with 87 cc's.
Re: Winter Project
How much are they charging for the nicasil plating? I didn't know anyone in the states did that!
Re: Winter Project
I think I just wet myself! Also that motor gets me exited. Thats going to be insane.
Re: Winter Project
Here is their website
http://www.mt-llc.com/
Re: Winter Project
So how did this project turn out?I hope it worked!
Re: Winter Project
yeah what happened with this?
Re: Winter Project
update plz
Re: Winter Project
bump for the updizzle.
Re: Winter Project
Sorry not much progress.
I got side tracked on building a drag scooter for a friend... he has some big race he took second in last year and he want to win this year... heres a early mock up pic.
Re: Winter Project
Raymond Wright IV /
freakin sweet!
Re: Winter Project
Great work so far man!
No reason it would no work. it's too bad the cylinder bolts are outside of the water jacket looks like you had to add a ton of aluminum.
Transfers appear to be about the size of the 85 parma I used, just be careful of the case bolt on the right side, your either going to blow right through it or get very close depending on how you port it.
Can't wait to see the end results.
Re: Winter Project
Thanks.... I have to get back on the project.. just too many friends have projects for me at the moment leaving no time for my stuff.
I will post more as soon as I get back on it.
I did get the cyl re nikasil'd nice to have freinds in the biz... was a freebie
Re: Winter Project
bump
Re: Winter Project
What happened to this i keep checking back and no progress!
Re: Winter Project
an update would be nice
Re: Winter Project
dean playing god on rafter's account /
another example of someone who should have waited until the project was done before opening their internet mouth about it. so lame.
Re: Winter Project
sick
Re: Winter Project
hope it wasnt a stock crank. i doubt that could hold up to the extreme forces.
Re: Winter Project
Man... no love here... lol
Sorry I just havent had time to work on it since the cyl came back from the nikasil place.
Everyone who walks through my shop also asks when I will finish it.
But they are the same guys that have me working on their projects for the upcoming season instead of my stuff.
When things slow down I will get back on it.
Re: Winter Project
what does the kx 80 crank look like compared to the puch crank because those kx 80 top ends put out some serious power.. more than any kit would dream of. wouldnt want to be snappin a con rod in those cases/cylinder
