So I opened up the the exhaust and intake ports on a 25mph moby. I am not running a base gasket but I do have a head gasket on. My plug looks a bit rich and the bike is only hitting about 28mph. I set the timing by pulling the cam and using a dial indicator to find 1.8mm B.T.D.C I then hooked up a static timing light and rotated the cam CLOCKWISE and just as the light started to turn on I placed the cam. When the points were opened I used a feeler gauge to gap them at 3.5 so unless I am confused about the timing it should be set. The bike boggs out a bit and dosnt seem to have the peppy pull that my old 35mph stock bike had.
<p>My question is would running a slightly off jet cause the bogging out feel? (I have a 60 in)
<p>When setting the timing do you want your cam to be placed by rotating the cam clockwise or counter??
