i took my v1 head off and i found one ring is missing on the bottom.
its doing about 24mph .how much gain can i get with one more ring? 30mph?
Uhhhh some people take one ring off a when using a kit to get higher rpms and higher top speed actually. Depends how bad your compression is with one ring, it should mainly help bottom end though.
yeah i've run on one ring on my polini all year. running two rings will up your compression, and give you a little more noticable takeoff but thats about it.
and 2 rings helps when you seize but other than that leave it at one.
