I'm building up a moby 50V with a 70cc AV 10 and am having some serious trouble finding cylinder studs. AV 7 studs will fit if you install them upside-down but then it's impossible to find nuts or a tap to make nuts.
Anyone know where these can be sourced?
I'd also be game for using studs from another engine. Anyone know of an engine that uses 5" long studs with M7x1 threads on both ends?
Thanks a ton for the help and see you at a so-cal rally when she's done.
