can i use a a35 speed kit on the a55
i have a tomos streetmate r and i would like to run the tomos moped alukit 70cc cylinder kit a35 targa sprint it is from ebay instead of intake it has reeds............would there be any problems
Re: can i use a a35 speed kit on the a55
this mod would probably be a little beyond you at the moment - the kit would ideally require serious port work to match the giant A55 transfers and you would need to find an A35 intake for that setup.
I'd start with a biturbo or other cheap tomos pipe, a uni filter, an upjet (58-60 to start) or so and a re-gearing. keep your stock front sprocket but go to a 24 or 22 in the back.
If you are still looking for speed i'd research the airsal kits and a carb/intake upgrade
How about a 55 kit on a 35? Whats the difference in the two?
yeah, it'll work just change your studs to an m7. and if you want open up your transfers. you dont really have to but you wont get that good of performance out of the kit. the a35 is a reed valve so you would need to get an a35 intake and reeds. the a55's intake is diffent and held on by two bolts(like a puch).
but if i where you id save up and get an airsal.
