The SHA filter is just a bunch of stacked screens wedged in the housing that you can pry out with a tiny flat head screw driver...
Remove the filter element. Pop out all of the screens with a tiny flat head... The The back screen has giant holes in it... then they get smaller...
I bought a 7 dollar metal mesh cone filter from the local dirt bike shop. Then I cut a piece out the same diameter and round shape of the SHA air filter element housing and put it in from the back so it was up front.. Then popped the screen with the huge holes in the back to hold it in.
Place it back in your sha and seal up the edge with electrical tape pulled super tight... Or your could just use a little rtv around the edge to hold it in there. They will vibrate out if you don't do something to keep it in without using the cap.
This is quick and easy and super high flow... Like almost zero restriction.
Done for less than 10 bucks and takes about 5 minutes to make...
I'm going to wiki it soon I think...
There are K&N filters that fit the Sha but they are HUGE and mad expensive...
