i would like to make my moped faster but don't want to spend to much any suggestion
gear change i would suggest a 24 in the back and search tomos in these forums/wiki
there is like a 30 some thing in the back now what will a 24 do for me
bigger in the front =faster top speed smaller in the front = better accelleration
smaller in the back = faster top speed
bigger in the back= better accelleration.
if you really want to dig in and have fun, just start reading all of the threads in the repair and performance forums, you will gain lots of knowledge on how to keep a fast running moped
so with a 26 tooth in the front and a 24 in the back how do u think it would work out......would it be much faster
The basics are regearing, performance pipe, and airbox modification. If you want to go further you can port your cylinder and get a very respectable speed. Use the search function and see waht there is to be done an an A35 or A55 engine.
do you have a peddle bike with gears ? put it on the lowest you have and pedal. it is easy but your top speed is slow. now put it in a higher gear, it is harder to start but you get more top speed.
my friend matt had a 22 tooth on the back of his.
he went almost 40 according to the tomos spedometer.
speed varies on weight/weather conditions etc.
but you will notice a very respectable speed improvement.
i was impressed when i put a 22 on my LX. 5mph increase for 12 bucks.
thats cool are there any kinds of heavy duty clutches for tomos
mix it with ce-ment
You don't need a heavy duty clutch unless your bike is heavy duty...its not.
