lowering front end.
what would be the best way to lower the front end of my moped about 1/2inches?
Re: lowering front end.
1inch.
Let the air out of the front tire. Seriously though, you could probably cut the springs down a little but you might run into problems with them bottoming out easy. If you have high end forks that use an adjustable tree you can slide the fork tubes up a little higher and then mount clip ons to the top.
Find stiffer springs from a dirt-bike/etc. that are the same diameter. Cut to length--enjoy!
Be sure to use a STIFFER/PROGRESSIVE spring when doing this...You make it too soft you waste $$$$.
are you doing it for looks or to make the bike super twitchy in corners?
