i made the exhaust port toooooo wide.
Now its broken, lame.
ha.
ha.
loser
butt sniffer
poo. how wide?
ouch.
cuperNEWB-O. Justin taught me EVERYTHING I know. especially how to ride.
Can you build it back up with JB weld? I know you can to that on intake ports, But mabes the exhaust is too hot.
worst idea ever.
The need to blast compels one to make unwise choices. broke = no blast!
If you took a piston and used a lathe to cut a 2mm ring land and found a ring to match it might work. And then it might not
wow, and after all the shit talk you blow up your kit. You look like a real DNA taster now...
ha
TREATED!!!!!!!!!!
run it without a piston ring
wot ftw.
just use eurocylinder 60cc kits
i opened up my intake and put a 19mm on it and it blasts
also casematching and piston work helped.
You can only squeeze so much blast from a cylinder till you over do it and the blast turns to sour defeat.
Treated
I now know the limit for the polini, i could have taken measurement and did the proper thing with like 70 percent of the bore or whatever but you know, thats silly.
crackstar you are a newb ill blast you anyday, my kit blew up because i pushed it beyond its limits, not jetting or putting it togther wrong.
plus now i got the hook ups.
Professional polini mechanic, suck it.
what????? you're having someone else do the work for you?
im not a newb.
you still taste DNA, you probably use both hands....
pushed it beyond its limits? if you could have blasted elliots polini i would fucking give you a high five. i doubt it did.
so justin tell us. what are the limits of a polini?
justin is still full of shit. 48 is slow.
48 with a proma circuit you retard zack. i hate you. zack im going to rape you the next time i see you.
uh oh!
he forgot "in the mouth"
