I got an exhaust with spring mounting for my peugeot, and I couldn't figure out where the springs are supposed to hook, other than to the exhaust. There is no spot on the cylinder or header for it to mount. So I drilled holes in the header and milled out an indentation so the springs could hook to it and not cause an exhaust leak. This works but it seems like it shouldn't have required machining.
