Jetting question
Help!, I've searched but come up empty on this one..
My moped ran great until I put a high-flow filter on it, when I noticed it was starting to run a little lean (obviously). So I drilled the jet (stock size 47 according to haynes manual, not labeled on the jet), but got a little excited and drilled wayyy too big. I ordered a new one from treats (size 50). It'll start and run with the choke on (albeit very slowly); and it'll idle with the choke off - however, if I give it any more throttle than that, it'll rev up for maybe a second, then die. Solutions?
Thanks.
Re: Jetting question
Sorry; some more details. It's an SHA carb, so no adjustments. Also, I noticed that the screw head part of the jet was quite a bit taller than the stock jet. Would this make a difference?
I hate to keep adding to this, but in case somebody glances at it..
I scraped some shite off of my stock jet; and despite the haynes manual saying it's a size 47, the one I pulled out was...80.
I'd say that's quite a bit of a difference. Obviously the 50 was waaaaaaay too lean.
So, in conclusion, to the other 4 people on the face of the earth that own NVTs - check your physical jet, not the manual.
Cheers.
Hi, im looking to put a new air filter on my 2005 derbi gpr 50 and im not sure how to upjet, could you tell me how?
thanks
Dude, that thing is HOT! Wish we had bikes like that in the states.. What kind of carb is on it?
order bigger jet, take bottom off carb remove jet that needle goes through ,get a bigger one from moped shop. put bigger one in. ride take out spark plug and do a plug chop. repeat till you get the right jet in there
