Re: moby porting ?
steve /
cool man. i'll put up some before and after port maps once im done.
do you have a port map of your cylinder before you ported? my biggest thing is that the ports on all the stock cylinders are _not_ the same. so say you had the "slow" version, and ported it to the wiki specs... the end result would not be the same as if you ported the "fast" version. this is obvious, and the wiki specifies to start with the "fast" cylinder... i want to know _the_ definition of the fast cylinder in terms of port sizes.
i assume since the cylinder i bought was a repro, it is the fastest model they had... why reproduce a crappy cylinder? also Nick at QK told me it was... i just want to compare my stock port maps to other people's.
