Re: korado wheel on maxi forks
Стев Браун /
Did you read his reply?
"nothing, it mounts right up"
There's a slight issue with mounting the rear rim on a Maxi swingarm, as the tab that holds the brake plate in place needs to be relocated, but other than that, it's smooth sailing. Some extra washers may be needed to space the rim, also.
