has anyone done a korado front wheel on their maxi?
im just curious what all has to be done..
nothing, it mounts right up
<a href="http://picasaweb.google.com/lh/photo/zJo5X4-9klb0FRBrepSuSg?feat=embedwebsite"><img src="http://lh5.ggpht.com/_9nZaBlBiDY0/SODgrcAnYxI/AAAAAAAAACU/tXQhNyW2Iws/s400/0514081908.jpg" /></a>
yeah, i know those are EBRs but after i broke those i put it on maxi forks
so what did you have to do? different axel?
Did you read his reply?
"nothing, it mounts right up"
There's a slight issue with mounting the rear rim on a Maxi swingarm, as the tab that holds the brake plate in place needs to be relocated, but other than that, it's smooth sailing. Some extra washers may be needed to space the rim, also.
