Re: 70cc kit express. 1 speed or 2?
I R E Rick /
black twingle , its so easy to remove the oil pump Clean the clamp and surrounding ares so dirt wont fall into your engine . Then just remove the clamp that holds it in place and pull it strait out . You may have to wiggle or twist a lil bit but it should come out pretty easy . Make sure the inside of the port where the pump was is clean and iol free . Maybe clean it with some alcohol on a Q-Tip . then push the IRE Rick OIL INJECTOR PLUG just slightly past flush of the surface of and tighten down until secure " Plug expands slightly " flush or slightly above the surface of the port . Then tighten down the locking acorn nut against the other and your done plugging your oil pump . You will also need to close off the line in the intake with some New tubing and a cap of some sort . Dont forget the oil tank feed line needs the same kind of treatment if it leaks between the oil and gas tanks . That should cover it all I think . Derek am I forgeting anything or maybe you have an even better way to take care of some of this?
  70cc kit express. 1 speed or 2?Topic by: Aj __iowa__ Aj __iowa__ 01/07/09 06:11PM
  Re: 70cc kit express. 1 speed or 2?Re: derek derek 01/07/09 06:23PM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 01/07/09 06:32PM
  Re: 70cc kit express. 1 speed or 2?Re: derek derek 01/07/09 09:00PM
  Re: 70cc kit express. 1 speed or 2?Re: derek derek 01/07/09 09:01PM
  Re: 70cc kit express. 1 speed or 2?Re: derek derek 01/07/09 09:06PM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 01/07/09 10:31PM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 01/08/09 04:12AM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 01/08/09 05:20AM
  Re: 70cc kit express. 1 speed or 2?Re: black twingle black twingle 01/09/09 11:42AM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 01/09/09 11:55AM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 01/10/09 12:06AM
  Re: 70cc kit express. 1 speed or 2?Re: derek derek 01/10/09 12:41AM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 01/10/09 01:16PM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 01/10/09 01:42PM
  Re: 70cc kit express. 1 speed or 2?Re: Silverfox Sullivan Silverfox Sullivan 01/10/09 02:52PM
  70cc kit express. 1 speed or 2?Re: Harry Crank Harry Crank 01/10/09 02:52PM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 01/10/09 04:46PM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 01/10/09 05:42PM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 01/10/09 07:10PM
  Re: 70cc kit express. 1 speed or 2?Re: Tate Tate 01/10/09 11:53PM
  Re: 70cc kit express. 1 speed or 2?Re: Harry Crank Harry Crank 01/11/09 11:04PM
  Re: 70cc kit express. 1 speed or 2?Re: Harry Crank Harry Crank 01/11/09 11:08PM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 01/13/09 03:38AM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 01/13/09 04:34AM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 02/19/09 12:35AM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 02/19/09 02:34AM
  Re: 70cc kit express. 1 speed or 2?Re: Nash . Nash . 02/19/09 08:48AM
  Re: 70cc kit express. 1 speed or 2?Re: Tate Tate 02/19/09 11:41AM
  Re: 70cc kit express. 1 speed or 2?Re: IRE Rick IRE Rick 02/19/09 12:19PM
  Re: 70cc kit express. 1 speed or 2?Re: Aj __iowa__ Aj __iowa__ 02/19/09 03:47PM
  Re: 70cc kit express. 1 speed or 2?Re: I R E Rick I R E Rick 02/19/09 06:07PM
