If you're having trouble getting into your pipes powerband, you need to look at your variators weighting scheme, not your flywheel weight. If your variator were tuned right... you should be riding your powerband throughout the variator's ratio range.
Fix the problem, don't modify the rest of the bike to get around the problem ;-)
