i gave in to the polini
humph.....
advice for super speeds?
Re: i gave in to the polini
loser
I looked at mine and I'm 99% sure my exhaust port is bigger than yours. We can compare tomorrow?
today?
blast
look up the posts about tightening the intake too much, save you a seize
hrmm yea i saw the intake thing on a video.
What reeds are used for bestest? 2 petal, 4 petal, dual stage, uber custom?
nine petal is super sick.
dude just skipthe reeds
the more pedals the better, melt banana style
it's fucking huge, but read this entire thread eliiot started about polinis. there's a LOT of good information in there.
that and watch out for your case studs when you're case matching. there's one that gets really close to the polini transfers. i got lucky.
noooo! you gave in.
just another maxi polini in the wall.
No maxi for me. Custom cuperteen special. keeping it real
don't worry, it will blast unlike most polinis.
Polini=power, but not for the mechanically declined...
polini can be as fast as the big kits but uber delicate.
if ur running a polini 4 pedal and it doesn't go 50 at least with stock gearing something is wrong.
most 4 pedal polinis round here with cheap pipes will hit 55+ on stock or close to stock gearing all day everyday. if ur going for reliability and speed stick with this setup.
add a good pipe and 60+ on stock gears is easy breezy but breaking polinis becomes a real threat. at those rpms.
a well tuned 2 pedal bing setup can do 50+ as well but most only ever see 45 however its good option for reliability as well.
I prefer the white stock polini reed paper in a malossi 4 pedal adapter on my bike
also belief that the malossi 4 pedal is bigger than the polini one is a myth fyi.
well thanks for the input.
i really want this thing to rip hard. low end and top end.
50 might be too much. I think im going to go for 45 with burn out capabilities.
So far the intake did not sit flat so i had to level it out. Four petal mallossi, but i think im going to change it to two big polini reeds and ill see how it does.
its wierd. Its so fast.
way more power than my kstar. Zack showed me the intake port mod and im plannning on doing it. What happens when you do.
you go fast.
bigger jets means you go faster.
oh and I wish I could ride to cuperteen land tomorrow.
Uhm, no, bigger jets does not = go faster
Sometimes you are too rich, and down jetting will increase speed
