av7 Airsal doing 43mph can it do 50mph
My set up is an av7 with Airsal 70cc kit, 15/15 Dellorto, Ninja g3, and mild case matching. I am currently GPSed at 43mph. I have a Dellorto PHBG 19mm and a stock head that was milled down 2mm. This is what I am wondering what kind of speed increase am I looking at if I install the high comp head and carb?
<p> note: the bike wont run with an air filter. Without the filter bike runs and idles perfect.
Re: av7 Airsal doing 43mph can it do 50mph
do some port work to that bitch and you could hit high 40's if not 50. there is a lot of room to fuck around wih the worts in that kit.
ports not worts. god damn i cant type.
So should I just open up the intake and exhaust ports? if so how much?
"_I have a Dellorto PHBG 19mm and a stock head that was milled down 2mm_"
<p> the 19mm and head are not installed what would happen if i did install them?
Yeah man....START with the PHGB. If the Airsal is anything like the 70cc Parma, then a 15 SHA will never get you more than 40's. You might also revisit the porting job you did on the case. I ported THE SHIT out of my case for the Parma and it flies.
And, obviously, the shaved head is going to help too.
My guess is that you'll have a mid 80's jet in the PHGB for that kit. Somewhere around an 86. Maybe 85. I think most of the Parmakits are happy around the low 90's.
start with that, install the 19 and the milled head and go from there. the ports on that kit are tiny, so you can open them up a good amount. i would say just go a millimeter at a time until you get what you want. talk to lester too, he could definitely give you some hands on porting advice.
whats a good recipe for higher top end on mobys? I am all stock now but i got a doppler pulley with a 12 tooth. I dont mind a slower start but I wanna keep up with my crews super fast bikes on our long rides.
GEARING recipe that is..
You shouldn't have to regear that thing at all.
I run around little over 55pmh all day long on my stock gearing, variator, and pulley. It's variated for a reason!
But if you want to keep up you might think about getting a performance variator like the Varplus from Malossi. It'll give you better low end and higher top end.
Otherwise, just do what Davey is telling you to do. There's lots of potential in the Airsal kit. It should do 50 pretty easily.
If you are still interested in gearing, this site has some great info, with a simple math equation, on gearing out the moby.
"11/54= 0.203703704 super potato and good point with standard kit G2 (100km/h)"
I don't know what a French potato is all about but that is 62mph. On stock gearing.
_HOW HIGH WILL A MOBY REV?_ holy crap.
potato is low end i think, assuming that point is top speed.
dude that's it, from now on "potato" is the new "acceleration"!
anyone got a cheap frame they want to mail me so that I can get this airsal av7 moby going.
Mich R, it might be stock gearing, but that is far from a stock motor!
So - say stock 27mph = 6000rpm (?????) then 43 = 9556rpm? That sounds reasonable.
Anybody have a clue what rpms they are running? My brothers Derbi laguna had a tach...
i love the number crunchers on here that think they can regear a stock moby and go 60.
I know you are not talking about me, as I read the title (and everything else) and this is an Airsal 70cc motor we are talking about here.
are you the guy i sold that kit to? if so, are you ever gonna send me back my clutch tool like i asked?
I guess not Josh... That sucks.
