Re: Question about decomp hole plug upz
Jesse Stephenson /
I don't see why it would distort the cylinder. The heat from TIG welding the hole will produce much more distortion than tapping the hole. If you are using a custom head then why don't you just make sure the head covers the hole. Make a head gasket that doesn't allow air through the hole. The only reason you would plug it is it makes an air leak in the exhaust and makes noise, so if the head covers the hole then why worry.
  Question about decomp hole plug upzTopic by: peter peter 12/26/08 02:40AM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 02:44AM
  Re: Question about decomp hole plug upzRe: Brennan O. Brennan O. 12/26/08 02:51AM
  Re: Question about decomp hole plug upzRe: Kansas John Kansas John 12/26/08 03:17AM
  Re: Question about decomp hole plug upzRe: Eric P Eric P 12/26/08 10:26AM
  Re: Question about decomp hole plug upzRe: human drew human drew 12/26/08 10:28AM
  Re: Question about decomp hole plug upzRe: human drew human drew 12/26/08 10:29AM
  Re: Question about decomp hole plug upzRe: Rick Wagner Rick Wagner 12/26/08 12:55PM
  Re: Question about decomp hole plug upzRe: Responsible Jon Responsible Jon 12/26/08 01:30PM
  Re: Question about decomp hole plug upzRe: Jesse Stephenson Jesse Stephenson 12/26/08 01:34PM
  Re: Question about decomp hole plug upzRe: Eric Sabatino Eric Sabatino 12/26/08 02:38PM
  Re: Question about decomp hole plug upzRe: naz naz 12/26/08 03:08PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 03:17PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 03:19PM
  Re: Question about decomp hole plug upzRe: Jesse Stephenson Jesse Stephenson 12/26/08 03:36PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 03:58PM
  Re: Question about decomp hole plug upzRe: naz naz 12/26/08 05:22PM
  Re: Question about decomp hole plug upzRe: Crackstar X Crackstar X 12/26/08 05:35PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 05:40PM
  Re: Question about decomp hole plug upzRe: nerobro nerobro 12/26/08 08:08PM
  Re: Question about decomp hole plug upzRe: zeke zeke 12/27/08 04:41PM
  Re: Question about decomp hole plug upzRe: Craig Craig 01/05/09 01:07PM
