Re: Question about decomp hole plug upz
Kansas John /
I've tapped and plugged the decomp hole on my puch kit, but you're right, yours is WAY closer. While in my head, I don't think tapping it out and plugging it would put weird stresses on it like the polini intake problem because the hole you're tapping would be parallel to the cylinder bore as opposed to perpendicular to it. That said, things that 'work in my head' are not something I'd expect you to try on a cylinder that costs over $100, and probably more.
Just another idea to try, would be to find a small piece of rolled metal bar stock that fits in the hole, and either epoxy it in, or like you said, put a lil' dab of weld at each end to keep it in there, and then grind, mill or sand it flat.
Wicked portmap, BTW. What kit?
  Question about decomp hole plug upzTopic by: peter peter 12/26/08 02:40AM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 02:44AM
  Re: Question about decomp hole plug upzRe: Brennan O. Brennan O. 12/26/08 02:51AM
  Re: Question about decomp hole plug upzRe: Kansas John Kansas John 12/26/08 03:17AM
  Re: Question about decomp hole plug upzRe: Eric P Eric P 12/26/08 10:26AM
  Re: Question about decomp hole plug upzRe: human drew human drew 12/26/08 10:28AM
  Re: Question about decomp hole plug upzRe: human drew human drew 12/26/08 10:29AM
  Re: Question about decomp hole plug upzRe: Rick Wagner Rick Wagner 12/26/08 12:55PM
  Re: Question about decomp hole plug upzRe: Responsible Jon Responsible Jon 12/26/08 01:30PM
  Re: Question about decomp hole plug upzRe: Jesse Stephenson Jesse Stephenson 12/26/08 01:34PM
  Re: Question about decomp hole plug upzRe: Eric Sabatino Eric Sabatino 12/26/08 02:38PM
  Re: Question about decomp hole plug upzRe: naz naz 12/26/08 03:08PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 03:17PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 03:19PM
  Re: Question about decomp hole plug upzRe: Jesse Stephenson Jesse Stephenson 12/26/08 03:36PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 03:58PM
  Re: Question about decomp hole plug upzRe: naz naz 12/26/08 05:22PM
  Re: Question about decomp hole plug upzRe: Crackstar X Crackstar X 12/26/08 05:35PM
  Re: Question about decomp hole plug upzRe: peter peter 12/26/08 05:40PM
  Re: Question about decomp hole plug upzRe: nerobro nerobro 12/26/08 08:08PM
  Re: Question about decomp hole plug upzRe: zeke zeke 12/27/08 04:41PM
  Re: Question about decomp hole plug upzRe: Craig Craig 01/05/09 01:07PM
