Exspansion chamber installation??
so i bought an exspansion chamber that slides onto the stock header pipe on a sachs. If the pipe slides on ok and fits. Should i cut off the extra header pipe i dont need? or should it just sit inside the exspansion chamber about 10 inches?
Re: Exspansion chamber installation??
YOu should cut it off. it's the transitions that make expansion chambers work.
cut
ok thanks guys
