are there any real prefomance boosts from having this carb? I'm currently running a 14 bing with a 64 jet.
Not so much if you are still running a stock exhaust... And even then...
no
14 should be awesome enough. Play with your gearing if you insist on keeping everything mostly stock.
moving from 14 to 15 will not make a difference and you will waste 100 bux (at least) on that carb plus intake. Jet a pipe and a high flow filter.
