Different sized transfers
On my autisa kit the left transfer is slightly larger thn the right. It there a reason for this or is it just a defect??
Re: Different sized transfers
if its super slight then its just casting defect. and not cleaned up at the factory.
you can probably do it yourself with a file.
but if its a huge amount i would be skeptical
i just put one on my fox and i filed it tell they mached and make sher you file all the ports they are sharp this is a grat kit
