since i have a pile of junk peds and parts now i figured i might as well start doing something with it
so i gut a batavus M48 case a solo crank and variator with a tomos A35 top end a puch flywheel and stator
man i cant believe it all fits together pretty nicely except for i have to dremel out the case for the tomos cylinder skirt and mill a bit off the sides of the cylinder to clear the case but it should work great
il just block up the hole where the original reed valve went
still more shit to do to it then build a fucked up frame to put it on its gonna look pretty fuckin weird
