new idea im building
since i have a pile of junk peds and parts now i figured i might as well start doing something with it
so i gut a batavus M48 case a solo crank and variator with a tomos A35 top end a puch flywheel and stator
man i cant believe it all fits together pretty nicely except for i have to dremel out the case for the tomos cylinder skirt and mill a bit off the sides of the cylinder to clear the case but it should work great
il just block up the hole where the original reed valve went
still more shit to do to it then build a fucked up frame to put it on its gonna look pretty fuckin weird
Re: new idea im building
Pics or it didn't happen.
In all seriousness this sounds pretty damn cool. I've always wanted to see a jalopy-ratped!
Unless the solo crank has a similar stroke to the Tomos, I doubt it will work very well. That being said, I'm very excited to see pictures, I love hobbled together machines.
tomos and solo have the same stroke
il get pics when its done
barrel length and crown height also need to be accounted for...
Throw a Puch high-compression head on that bitch and your journey to the dark side will be complete.
🇮🇹💦 Of the Loin /
the solo crank fits into the batavus case? I know the m48 and the solo are similar looking
it fits almost perfect i had to grind a bit off the webs where the forging is all rough its gonna have a lot of case compression
im very dissapointed that a honda express stator cam and flywheel will not fit at all to have a cdi
il have to try a daelim pointless ignition mag it might fit i dont know or maybe one from a jawa to make it even more fucked up
🇮🇹💦 Of the Loin /
its a bosch just throw a peugeot ignition setup on it AHAHAHA
a sachs motoplat ignition m aybe
derbeez ryderz /
pics!
puch ignition on a za is same as on a m48 (pretty damn close)
Bump for pics of the Frankenped.
soon im puttin new bearings and seals in it tonight and im gonna gring a bit off the crank then put the case together
well actually i gutta machine the case so the cylinder will fit then port match the cylinder to match the case
its gonna work great im not sure how good it will go but il find out
roadent$ craig /
please put this on a hs50
if i had one i would
so?
derbeez ryderz /
i know this is going to happen considering the builder, but we gotta see pics
i put it off for a bit cause i gutta get some other stuff done i have people waiting for their bikes to be done
i still need to order 1 seal for it
