Can I get some ideas on the correct or "best" Dremel bit for exhaust port cleanup. I'm clearing a Korado cylinder...
I poished my port on my airsal last night with a finishing abrasive bit. Lookes like a little red or dark grey brillo pad that attaches like the cutting discs to the shaft bit (with the screw in the end). Looks like a mirror now
thats my best description...Walmart has them
Dremmel 511 Finishing Abrasive Buffs..they come in two packs...fine and coarse
I just use a red grinding bit and very lightly run it over the surface where I see inconsitancies, then some polishing compound using the rubber bit, then finish up with the white fuzzy one... Mirror shine.
Thanks for the ideas gentleman...
You might have better luck with a round file.
that would be good for the inconsistencies but not the polishing...
naw...you gotta have some power behind the bit...gotta have it on a motor. My opinion
"this":http://forum.mobcustom.com/vt46063-tuto-preparation-simple-cylindre-av7 Frenchy thinks differently. It's a great little write up that you can just take the basics from and apply to any cylinder you wish.
