if you want, you can change to a needle with a slightly wider end taper. But keeps the relative shape of the rest of the needle. check the needle chart and look at what shape yr needle is. and look for another needle that is slightly fatter at the end/tip. thats a very crude explanation. this is assuming your mainjet is tuned right. what needle do you have now?
