Re: Pet peeve. Learn yr PHBG jets.
elliot /
I agree that overly large carbs are not needed in many applications and that a simply a larger carb will not yeild more power for that mod alone. For example often stock mobys will have better performance when using a 14:12 carb rather than a 15:15 carb this is because the emulsion tubes on the 14:12 are more appropriately metering fuel for the design of the av7 motor, the 15:15 emulsion tube is simply the wrong jetting and results in a low end bog.
Proper tuning any carb and motor will yield better results than just a larger size or smaller size alone. i use a 19mm carb on my polini 4 pedal setup because thats the size of the intake tract. why would i choke the circuit with a 15mm phbg, i certainly won't get more power from the 15mm carb if it restricts my intake tract, however i doubt i will see much gain if i implement a 21mm phbg.
I always call that jet a pilot jet because i want to dispel the myth that it is only for an idle function. the choke jet does nothing but enrichens the air fuel mix with more fuel when engaged (by fuel i assume everyone knows not strait gasoline but premix.. another word choice issue that happens alot)
my biggest pet peeve on here is number and theory slingin ppl who don't even have a fast bike ;)
  Pet peeve. Learn yr PHBG jets.Topic by: MarkRyan MarkRyan 12/13/08 01:09PM
  Re: Pet peeve. Learn yr PHBG jets.Re: MarkRyan MarkRyan 12/13/08 01:15PM
  Re: Pet peeve. Learn yr PHBG jets.Re: leedog leedog 12/13/08 02:17PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Noah K Noah K 12/13/08 02:23PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Tommy Too Tall Tommy Too Tall 12/13/08 02:46PM
  Re: Pet peeve. Learn yr PHBG jets.Re: leedog leedog 12/13/08 02:49PM
  Re: Pet peeve. Learn yr PHBG jets.Re: 💀Kim Jong illest💀 💀Kim Jong illest💀 12/13/08 03:14PM
  Re: Pet peeve. Learn yr PHBG jets.Re: finny finny 12/13/08 04:23PM
  Re: Pet peeve. Learn yr PHBG jets.Re: nerobro nerobro 12/13/08 09:27PM
  Re: Pet peeve. Learn yr PHBG jets.Re: davey davey 12/14/08 07:04AM
  Re: Pet peeve. Learn yr PHBG jets.Re: MarkRyan MarkRyan 12/14/08 07:21AM
  Re: Pet peeve. Learn yr PHBG jets.Re: nerobro nerobro 12/14/08 12:44PM
  Re: Pet peeve. Learn yr PHBG jets.Re: MarkRyan MarkRyan 12/14/08 01:45PM
  Re: Pet peeve. Learn yr PHBG jets.Re: nerobro nerobro 12/15/08 12:29AM
  Re: Pet peeve. Learn yr PHBG jets.Re: bfa bfa 12/14/08 02:58PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Tom STL Tom STL 12/14/08 03:22PM
  Re: Pet peeve. Learn yr PHBG jets.Re: [[ Linda ]] [[ Linda ]] 12/14/08 03:35PM
  Re: Pet peeve. Learn yr PHBG jets.Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/14/08 03:32PM
  Re: Pet peeve. Learn yr PHBG jets.Re: JonVDB JonVDB 12/14/08 08:52PM
  Re: Pet peeve. Learn yr PHBG jets.Re: leedog leedog 12/14/08 03:53PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Jon P Jon P 12/14/08 04:15PM
  Re: Pet peeve. Learn yr PHBG jets.Re: MarkRyan MarkRyan 12/14/08 04:43PM
  Re: Pet peeve. Learn yr PHBG jets.Re: bfa bfa 12/14/08 08:26PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Eric Sabatino Eric Sabatino 12/15/08 12:30AM
  Re: Pet peeve. Learn yr PHBG jets.Re: zachlee zachlee 12/15/08 12:36AM
  Re: Pet peeve. Learn yr PHBG jets.Re: bfa bfa 12/15/08 01:15AM
  Re: Pet peeve. Learn yr PHBG jets.Re: davey davey 12/15/08 01:29AM
  Re: Pet peeve. Learn yr PHBG jets.Re: Jon P Jon P 12/15/08 01:30AM
  Re: Pet peeve. Learn yr PHBG jets.Re: bfa bfa 12/15/08 02:33AM
  Re: Pet peeve. Learn yr PHBG jets.Re: zachlee zachlee 12/15/08 03:33AM
  Re: Pet peeve. Learn yr PHBG jets.Re: Maggie Bandit Maggie Bandit 12/15/08 06:29AM
  Re: Pet peeve. Learn yr PHBG jets.Re: davey davey 12/15/08 11:53AM
  Re: Pet peeve. Learn yr PHBG jets.Re: Graham Motzing Graham Motzing 12/15/08 12:43PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Chris Rice Chris Rice 12/15/08 06:38PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Chris Rice Chris Rice 12/15/08 06:39PM
  Re: Pet peeve. Learn yr PHBG jets.Re: elliot elliot 12/15/08 09:10PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Shalerrr rrr Shalerrr rrr 12/15/08 09:24PM
  Re: Pet peeve. Learn yr PHBG jets.Re: elliot elliot 12/15/08 10:59PM
  Re: Pet peeve. Learn yr PHBG jets.Re: nerobro nerobro 12/16/08 12:06AM
  Re: Pet peeve. Learn yr PHBG jets.Re: bfa bfa 12/16/08 12:13AM
  Re: Pet peeve. Learn yr PHBG jets.Re: nerobro nerobro 12/16/08 01:19AM
  Re: Pet peeve. Learn yr PHBG jets.Re: bfa bfa 12/16/08 02:55AM
  Re: Pet peeve. Learn yr PHBG jets.Re: Nerobro Nerobro 12/16/08 02:16PM
  Re: Pet peeve. Learn yr PHBG jets.Re: davey davey 12/16/08 03:32PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Tracy Tracy 12/16/08 03:48PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Nerobro Nerobro 12/16/08 03:56PM
  Re: Pet peeve. Learn yr PHBG jets.Re: MarkRyan MarkRyan 12/16/08 03:56PM
  Re: Pet peeve. Learn yr PHBG jets.Re: MarkRyan MarkRyan 12/16/08 04:11PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Kansas John Kansas John 12/16/08 04:15PM
  Re: Pet peeve. Learn yr PHBG jets.Re: davey davey 12/16/08 04:19PM
  Re: Pet peeve. Learn yr PHBG jets.Re: bfa bfa 12/16/08 04:45PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Nerobro Nerobro 12/16/08 05:00PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Chris Rice Chris Rice 12/16/08 05:52PM
  Re: Pet peeve. Learn yr PHBG jets.Re: Kansas John Kansas John 12/16/08 06:20PM
  Re: Pet peeve. Learn yr PHBG jets.Re: David Ciao David Ciao 12/16/08 09:53PM
  Re: Pet peeve. Learn yr PHBG jets.Re: hippy on alicia hippy on alicia 12/16/08 10:06PM
  Re: Pet peeve. Learn yr PHBG jets.Re: elliot elliot 12/16/08 11:37PM
