So if I get the 70 cc malosi kit, and my 19mm carb/intake... Is port matching the stock case a must? this is nerve wracking for me as I don't know how much to take off, and really don't want to damage the case.
no, but i can give you tips what kind of engine a Puch E50?
very little to be taken off, more like a chamfering just clean up the edge to match idealy only go in no more than 1/2 inch
Email me~SABAT!
He's talking about the peugeot kit. Yes, you have to match the third transfer.
just trace the base gasket and dremel it out.
how deep would I go to match the port? like the size of the port down all the way? angle it?
Angle it. And look at the case and keep in mind not hitting any bolt holes.
Perfect, thanks noah! I'll use search function to find the bit and stuff i need.
be sure to dip the dremel bit in some cutting oil or something to keep it free of the metal that will clog it up.
just a tip. good luck! its pretty easy. just take it slow.
