Re: Peugeot 103 tuning--- running reeeally hot
nerobro /
did you do a plug read? That will answer your plug question.
Motors can run VERY hot without any real danger. Especially if you run syntheic or castor oil. Motors seize when they get hot enough to break down the oil (and that's REALLY hot..) or if they get differential heating. For instance, if you rev a motor to redline on the centerstand.
