Re: motobecane 51V upgrades
Shalerrr rrr /
ventilxp crashed and is now a shadow of its former self. they lost all their content.
you want to do this:
dellorto 15:15 carb with a jet in the mid to upper 70s.
doppler ER3 reed setup. these are carbon fiber and let in waay more air than the stock setup.
check and see if that bike has a 3 or 4 ball variator. i'm betting its a 4. if it is, take it apart and take two of those balls out.
widen the exhaust port about 1mm on each side, raise it about 1-2mm. this wont hurt anything, and stock AV10 cylinders are a dime a dozen.
get a 50cc malossi hi-comp head with the decompression valve.
i bet that bike has points too. make sure all that stuff is in good shape, and you may want to retard the timing just a 'lil bit. none of this will change the appearance of the bike whatsoever and you'll be very pleased with the results.
  motobecane 51V upgradesTopic by: mike park mike park 12/08/08 12:41AM
  Re: motobecane 51V upgradesRe: tuna sled tuna sled 12/08/08 04:30AM
  Re: motobecane 51V upgradesRe: paulvolio paulvolio 12/08/08 08:22AM
  Re: motobecane 51V upgradesRe: mike park mike park 12/08/08 12:54PM
  Re: motobecane 51V upgradesRe: mike park mike park 12/08/08 12:58PM
  Re: motobecane 51V upgradesRe: motobee motobee 12/08/08 01:43PM
  Re: motobecane 51V upgradesRe: mike park mike park 12/08/08 01:52PM
  Re: motobecane 51V upgradesRe: finny finny 12/08/08 02:40PM
  Re: motobecane 51V upgradesRe: Shalerrr rrr Shalerrr rrr 12/08/08 02:52PM
  Re: motobecane 51V upgradesRe: mike park mike park 12/08/08 03:04PM
  Re: motobecane 51V upgradesRe: Shalerrr rrr Shalerrr rrr 12/08/08 03:06PM
  Re: motobecane 51V upgradesRe: mike park mike park 02/08/09 03:49AM
  Re: motobecane 51V upgradesRe: Emperor Swagustus Emperor Swagustus 02/08/09 03:57AM
  Re: motobecane 51V upgradesRe: mike park mike park 02/08/09 04:11AM
  Re: motobecane 51V upgradesRe: PAULVOLIO PAULVOLIO 02/08/09 08:49AM
  Re: motobecane 51V upgradesRe: Mick Baltards Mick Baltards 02/08/09 10:30AM
  Re: motobecane 51V upgradesRe: Emperor Swagustus Emperor Swagustus 02/08/09 12:50PM
  Re: motobecane 51V upgradesRe: mike park mike park 02/08/09 02:39PM
  Re: motobecane 51V upgradesRe: mipark56 mipark56 02/08/09 02:43PM
  Re: motobecane 51V upgradesRe: Andy Andy 02/08/09 06:56PM
  Re: motobecane 51V upgradesRe: ffreddie ffreddie 02/09/09 03:35PM
  Re: motobecane 51V upgradesRe: mike park mike park 02/09/09 06:15PM
