where to get peugeot 102SP pipes or expansoin
desert rat /
chambers?
need to know where to get a pipe or expansion chamber for a PEUGEOT 102 SP not 103 any help would be apprieciated thanks
You need to make a pipe made for another bike fit yours. Pipes for 102s just aren't available. So, grab a biturbo/bullet/boss/estoril/whatever and make it fit your peugeot header.
Re: where to get peugeot 102SP pipes or expansoin
Treats has that twin pipe that's supossed to work on the 102, not sure though.
I think you could just use a 103 pipe.
The threads are the same as a 103 but the angle the motor mounts is way different so a 103 pipe would hit the ground without modification.
Twin pipe from treatz works. I put it on my 102 sp and it ripped! Plus it's super sexy and the lay-deez dig it. mounts onto the frame just behind/underneath the engine. Only thing you gotta watch out for is interference with the pulley on your pedal crank.
