polishing exhaust ports
What should the finish be on the inside of an exhaust port?
I know that polishing the port reduces carbon buildup because it can't stick to a smooth surface, but does it hurt preformance?
Airplane wings actually have a rough surface to increase the flow of air over the wings.
I believe that polishing ports makes air stick to the port by increasing friction. Just think of trying to drag one piece of sheet glass over another.
Discuss...
Re: polishing exhaust ports
Well, polishing reduces the small bumps in the aluminum port, which should reduce friction.
i think 2 pieces of glass sticking together has more to do with the molecular properties of glass and the structure of the molecules.
dittp what jon-o said about the glass....really no discussion needed about the exhaust port either, read any literature on two strokes or on gas flow and it will say the smooth is better
▣ß@ηℊℙℐṔ∃▣ ™ /
all the planes i have worked on are usually polished aluminum?
mirror finish. that's what i shoot for
Haha. This is te most discussed subject in Holland.
It seems very logic that a polish't surface is the best.
Butt probably it isn't.
Take the plane thing. Throu that it's as smooth as possible to reduce friction.
But with a moped engine there is more than just air!
There is also gas and oil. When you sand (not polishing) the transfer-ports. The oil that is in the mixture wil stick to the transfer-ports wall. This tiny oil surface is much smoother than that you can ever polish it. So? probably sanding the transfers is better than polishing.
yeh, transfers=smooth but not polished because its not a gas flow, its actually a suspension of liquid droplets....exhaust=polished because it is now a gas (hopefully, depending on how good the combustion is)
Like this pic polishing helps reduces carbon build up to.
Fast bat out
