I really just wanted to try something new and see if i could get more power out of it or if it wouldnt make any difference. So far It seems about the same as it was before the reeds, except I had to richen the idle mix a bit. It is also super quiet compared to the non reed intake. As I mentioned before, I havent done any porting or cut any boost ports yet. By using the reeds and boost ports I was hoping I could get more efficient cylinder filling due to a longer intake duration and more power or at least a different performing power band. Its all just an experiment to see what it can do. Next project may be case induction.
