Tuning & Maintenance for Tomos ST '07
Hi Moped Army,
This is my first moped, It rides decently and only has a 1000mi on it. I'm looking forward to riding with Guns come spring. The moped had some trouble starting after being transported sideways, and it is still weird, cleaning the spark plug seems to have helped. Essentially, it either takes a while to start, or when it runs the throttle is jerky, or it runs a few miles till it dies when you come to a stop. I also rode it 25mi the other day and it ran fine. I think its the valve as the far CCW setting seems to run well so far. Ideas?
I'm also not sure what the orientations on the Gas Valve are, the manual incl. was '06 maybe. I wanted to run what I've plan to do with it and get your opinions.
I don't know the maintenance history so I'm starting there.
1)Gearbox Oil Change:AMSOIL Formula 4-Stroke
Re: Tuning & Maintenance for Tomos ST '07
1)Gearbox Oil Change:AMSOIL Formula 4-Stroke 10W-40 Synthetic Scooter Oil
Well, it's not a 4-stroke, or a Scooter, so instead, I recommend:
Also, I have no idea what "I think its the valve as the far CCW setting seems to run well so far. " means, as there aren't valves and I have no idea what a CCW setting is... Counter Clock Wise? Hm. I'm lost.
that transoil stuff is great.
and yeah, valves? 2 strokes dont have valves.
i meant the gas selector switch, off, on or reserve. ccw is indeed counter clockwise
I decided on Spectro instead of Amsoil or Motul, rather order everything from one place. Probably skip on iridium plugs as well.
I gotta say, that Motul Transoil's a dream. If you ever get to checking it out, please post which worked better, that or the 10w40 four stroke stuff.
Also, pet cock (or fuel cock, a.k.a. gas selector switch): 12 o'clock, gas, 3 or 9 o'clock off, 6 o'clock reserve.
