Minarelli there are actual Minarelli brand high compression heads that look more "square" than the stock ones. There are also south american high comp heads. And there is the head on the safari turbo version of the V1, that engine has both a high comp head and a needle bearing stuffed crank, and a cylinder with better ports.
